i'm about change the cambelt on my grandson kangoo what special tools will i need, and is there anything i should watch out for.
What does the locking it consist of,and can you make your own.Hello and welcome to the forum.
You will need the locking kit,the crank pulley isn't key wayed so is free to move on the crank,you need to lock everything up and make sure the crank doesn't move!.Hopefully you're going to fit a belt kit,it should have a new crank pulley bolt in it,if it doesn't then get one as it must be replaced.
Although the dCi is common rail,the fuel pump still needs to be timed up as the camshaft sensor works of the pump pulley,this is an odd idea and catches some people out.On 99% of common rail engines the pump doesn't need to be timed up as all it does is provide high pressure diesel,but the 1.5 is an exception to this and if the pump isn't timed up the cam sensor will read incorrectly and cause starting/running problems.
lagtdi;732919 hi thanks for your reply what does the locking kit consist of,and can you make your own.:dHello and welcome to the forum.
