Re: 2008 Renault Grand Espace 2.0 DCi with Panoramic Roof
One of the 4 metal brackets (the ones that slide) that hold the sunroof has rusted.
However, I cannot find this part for sale anywhere.
I see sunroof repair kits for the Renault Megane and Scenic which have similar metal brackets and clips, but they look a wee bit different. The one on the Espace (which I removed) is a slightly different design/shape with a fixed white plastic bit at one end and a rubber clip in the middle.
Does anyone know where I could find one?
And could the ones for the Megane/Scenic work (but I doubt it).
has anyone else had this problem?
Very grateful for any help as I have run up against a brick wall.
Hello and welcome to the forums
you could try and speak to one of our site sponsors RENPARTS, they might be able to help you with the part you need
or you could get the engine code off the oval sticker ( it is the 4 digit code top right of all the information) and have a look here PARTSOUQ
