1 - 1 of 1 Posts
If you are getting drumming at low speed and setting off
and your car is fitted with a sunroof then think about
nipping up the 12 or so 10mm bolts that hold the sunroof
frame to the roof, pull off the trim then with a flattish
ring spanner just pull the lining down a little so you can
slide the spanner in and tighten any loose bolts 10/15
min and you will have a more pleasant car to drive in traffic.
:mechanic:
1 - 1 of 1 Posts
