Good day,I have a Renault Clio 1.4,ignition goes on but won't start,and also no fire ,any ideas would be appreciated.
TIA
Assuming the immobiliser light is doing what it should but the engine is not cranking.....
Check large fuse on battery positive terminal.
Check earth straps.... a jump lead between battery negative and the engine block bypasses what may be a bad earth.
Check 12v at starter motor large connection, permanent.
