Hi, I have Megane 2013. Removed sd card for updatetes and when inserted back, Carminat didn't accept sd card. Started loading, once got to 54% received message to remove the sd card. Also bought new SD card but didn't work either. Please support.
Motor vehicle Rectangle Gadget Cameras & optics Font
Automotive lighting Rectangle Gadget Bumper Font
Motor vehicle Automotive lighting Automotive design Hood Rectangle
Did you go into the menu and use the remove card feature before taking it out?
clio 1.5 dci 2012
Ive made the mistake of just taking the sd card out ,without the prompt and it didnt cause any problems
Put a formatted sd into the system and turn it on. The unit should automatically pair itself to the card and warn you not to turn off or remove card until complete. Once done you’ll be prompted to remove the card. Take card to your pc, login to Tomtom home 2 and place your new maps onto it using the backup feature.
Take card to car and put into Tomtom unit (whilst off) and then turn on unit. Hopefully this will solve your problem.
HTH
