can anyone help i have an ex british gas kangoo 17dci van and have the problem that when i am going along the central locking activates on its own then the hazzard lights come on, i have to turn the hazzard light on then off then 10 to 15 seconds later it happens again, as you can imagine it is a bit of a pain especialy in town.
there was as special british gas locking system installed but when the van was in warranty it was disabled because it wouldnt lock
any help would be great
thanks
kangoo flashing hazzard with central locking
the fault is intermintant and because i use it everyday being self employed i put up with it, but talking to the garage i bought it from they told me of a sensor in the side door that might be the problem,
does your side door lock if you undo your filler cap?
give us a reply and i will get imformation to you because i am going on holiday at end of week and its a good time to get it sorted
No the door does not unlock (I haven't got the side loading door!!) Have been trying to find the hazard relay but have now been informed that it is built into the fuse board and can not be changed!!! any help is much appreciated.
