My central locking has been playing up today, well actually its just the key..
u press the button and the red light comes on but the doors dont lock/unlock. gotta press like 5 times for it to work..
dont think its the battery.. changed that last yr..
what could it be? anyone had similar problems with their key and how did they fix it?
i think its just the button itself on my key..
cheers
Discussion Starter #2
Also i was wondering, if someone could tell me where the sensor is which recieves the signal from the key, maybe that could have moved or maybe dirty or sumthing?
coz i have had it serviced in the last 2 weeks..
RIP 31-12-2008
Not sure about Clio's but the sensor in Laguna 2000 is in the overhead console just in front of the interior light/map light, if you have a similar set up just in front of the overhead lights there will be a small crack/join. if you put your thumbs just in front of this and push towards the windscreen the sensor will slide foreward and drop down,it is connected by a small plug. sometimes the plug and circuit board do get a bit damp
Regards Leroy
