Ive just finished doing the head gasket on a renault kangoo 1.2 d7f 720 engine got to the end and the dreaded it doesnt start it has fuel geting to the injectors but has no spark any ideas?
its a hard one without seeing the car, you need to systemattically go through everything you have touched, concentrating on the ignition ht and lt wiring.
well i have voltage to the coil but down the earth wire from the coil i can make a connection from the plug to the wire before black part you bolt down for thew earth but not actullay on the earth terminal itself could it be the black part i do not no whats inside?
