A simple but very frustrating problem! - How do you remove the rear bulb holder on the Megane Sport Tourer?
According to the manual, you simply push it up from the bottom. However, having spent 2 hours trying to do this, It does not appear to move enought to come out?
Any constructive advice would be greatly appreciated.
Wilbar
If it's anything like the Laguna ST then yes you do just push the plastic covers up. There are "plastic lugs" which stick out and grip between the trim and the cover. It is just a case of pushing up and across slightly so one side becomes free ( or one end) then you should be able to prise the rest of the cover off to gain access to the bulbs.
Thanks for the advice, sport tourer. I have now managed to change the bulb.
Wilbar
You're welcome. Glad you managed to sort it.
Thanks for taking the time to come back to us with the result. It is so often the case where people take advise and never get back to us. Cheers.
