How much of a job is it to change tappets on the 2.0 16V engine on my Laguna 2.0S. It has a little tapping sound when cold which soon goes away, but if this gets worse i guess i'll need to change the tappets which are worn or sticking. I take it that these are hydraulic ones are they?
It might be an idea to change the oil and filter(using a flush) and using some good quality correct grade oil with a genuine oil filter.
I think I'm right in saying that your car has the Volvo engine in it(oil filler cap in the centre of the rocker cover),and as yet I am unaware of anyone having had to change the tappets.....but theres always a first time!:)
It sounds like that is the engine yeah, its only done 70K too. I am going to change the oil next weekend and see if that helps. Thanks for the reply :)
changing tappets on laguna 2.0D 16v
I also have big tappet noise on my laguna 2.0S 16v
I've tried changing oil, oil filter of course, new plugs, new exhaust, RedEx-ed the petrol... Am at a loss as to what to do next???
Same with mine at 182k, hyd tappets dont generally fail but can get gummed or blocked orifices.
Gonna try flushing oil first myself too.
