Hi does anyone know how to remove the 2 pipes on the charcoal canister on my 2001 mk1 renault scenic i dont want to break them
In my experience, these pipes are conventional 'fuel' type connections (i'm sure someone else here knows the proper name for them). Push the coloured section on the side, or the two coloured sections on opposite sides and it should release.
Sometimes, if it's a little stiff, push the connection down whilst pressing the coloured sections and it makes releasing it a bit easier. There are special pliers for this purpose but accessibility is not always ideal. And usually can be done by hand anyway.
Picture?
p.s. why do you need to remove the pipes on the charcoal canister?
#curious
Discussion Starter · #4 ·
So i can remove it to make it easier ,Useual problem broken bracket iv put a couple of cable ties on it for now till i can make a replacement one
