Hi, I have a check emissions fault on my Renault Scenic 1.6 petrol.
I have been told that the fault codes are:-
PO340 CMP SNSR A CCT B1 OR SINGL E SNSR
Obviously there is a sensor fault any ideas which one?
Thanks in advance
Derek
P0340 is a generic code for camshaft position sensor failure or somewhere in the circuit.
I know this because i've just googled it.
It may be a faulty sensor or just a bad connection, loose wire etc.
What did the mechanic at the garage say?
