Hi anyone help I have a clio 1.5dci 64 plate it keeps saying check hillstart check esc and check abs it's not coming up with any codes aa said its brake switch which I have changed but it still won't go off plus cruise control stopped working thanks
Those faults all set off by default. It's to prevent you doing any damage to those modules. If you've replaced your brake switch and the problems started after you did that. Then the brake switch is your problem.
Are your brake lights stuck on all the time
