Hello everyone. I bright a Renault grand scenic last week. 1.5dci 2011.(Sold as seen) today when I started it 'check injector system' came up on my dash.
I had a little look under the bonnet to see if I could see anthing out of the ordinary. But I saw a loose bracket of some sort. Could anyone tell me what it is? It's just above the oil tank, it clearly has a bolt missing, potentially causing a leak of some sort. I'm absolutely clueless with cars. So hoping someone knew what it was, if anyone has had an issue, what bolt is supposed to be in there?
Any help is much appreciated.
Could do with a more overall shot so we can see what part of the engine that bracket relates to
