can any one help i've had my renault scenic mark 2 o3 reg for three weeks and this chirpping noise as started coming from near the belt pully's :confused:
O
It could be anything, but how loud is it? Is it only when cold?
If you add a small amount of water to the auxilliary belt, does it go away?
It could just be a less than tight aux belt.
i can hear it when i'm driving , park it on the drive at tea time and notice some water on the floor
O
Water on the floor suggests a water pump failure and it would explain the noise as well.
Get it checked at a garage, as it's hard to say without hearing it.
When is the timing belt due? It will have to be taken off to do the water pump, so if it's due I'd get it done very soon.
