Hi is there a way to easily change the silver on the climate control to black?
Mighty2000Mouse · Registered Joined 15 d ago · 2 Posts Discussion Starter • #1 • 6 d ago Hi is there a way to easily change the silver on the climate control to black?
Dancingdad · Super Moderator Technical Supremo Platinum Member Joined Dec 5, 2013 · 25,840 Posts #2 • 6 d ago Weee Probably the easiest way is to see if all black versions were made and if any available. Otherwise it is suitable paint or similar
ajc1200 · Premium Member Joined Nov 13, 2017 · 538 Posts #3 • 6 d ago You might be able to use a sticky back vinyl 'wrap' material.... like they use for exteriors or roof and mirror details. A dark grey might match the other plastics, or carbon fibre look?
Dancingdad · Super Moderator Technical Supremo Platinum Member Joined Dec 5, 2013 · 25,840 Posts #4 • 6 d ago Water transfer or hydrographics is often used to put a top coat on parts. Water Transfer Printing Hydrographics Applying Printed Designs To Three-Dimensional Objects - YouTube You could probably find someone in your area or look at a DIY as some you tube vids seem to show. But would need to get the silver parts off or mask the bits you want to keep black. I love the process though, seems like magic the way it applies. This with paint How To Hydro Dip ANYTHING! TKOR Guide To Spray Paint Hydrographics and Hydrodipping DIY - YouTube This with film How To Hydro Dip For Beginners 2.0 - YouTube
