Hi All,
I'm new to the forum. I have a problem which has been covered extensively on here and elsewhere, but I can't find anything with my specific symptoms and would like any feedback on my approach.
A couple of weeks ago I bought a 1999 clio 1.2 16v in nice used condition, drove for a couple of days both motorway and town, and then the warning light came on and it went into limp mode. I turned it off and on again and it started and ran perfectly.
Since then it has got more frequent. What I think is telling is that it starts from cold immediately I turn the key and runs perfectly for a good half an hour before the limp mode kicks in. Thereafter it will run for a couple of minutes to much longer before limping again. Each time it does it I just have to stop and restart and it's good to go.
I have checked for general chaffing on the loom and found and resealed one wire, the copper seemed undamaged, from the ecu plug to the 15amp ignition fuse and removed and checked the various other plugs for obvious problems.
Is it unwise to assume that the problem is related to the temperature of the engine and that there is probably a faulty temperature sender or semi-break in that part of the loom? I understand from various forums that the trouble with having the problem diagnosed is that the inherent problems with the loom can confuse the diagnostics as much as the ecu and that many people have replaced many parts at great cost and to no avail.
Possibly unconnected is that the car starts perfectly from cold, but when hot it needs some throttle and turns over 2 or 3 times before starting, though it does that perfectly reliably. Again a heat related symptom, but possibly a red herring.
What do people think?
