Hey all,
Newbie here.
I recently bought a 2012 1.2 16v clio tomtom to run around in. I'd like to drop it by 60mm. Can anyone suggest a economical set of springs? I cant find any brands that do 60mm.... thanks.
Hi Matt.
Quick search (as you already have probably done) seems to find 30-40-50mm lowering springs available for the Mk3 but not 60.
People like Losuspension do 60mm kits for the Mk2 but not it seems for the 3.
Have you checked that you will still have tyre clearance, at full lock, if you go the full 60?
Sexy at 70 super duper mod..
Good luck on speed bumps..lowering that much puts your drive shafts at an un-natural angle and a strain on CV joints and the like and you will need a full geometry check if you do it..
