Been having numerous problems with my Clio. Its a 52 plate Expression +, 1.2 16v 43k miles on the clock.
Bought it in Dec 05 from a dealer and got a 2 year warranty.
Main issue is that its using a lot of oil. There's no leak from the sump. Filled it on Sunday then did a 180 mile trip on Monday only to find oil half full on return.
Starter motor was replaced under warranty 4 weeks ago and now car is turning over but not firing - gets there eventually.
Dealer is useless - just hooks the car up to the diagnostic machine which says no fault every time. 3 times they've looked at it and 3 times they've found no fault.
Its also spluttery even when warm, but again dealer says nothing wrong.
Anyone got any ideas?
Hello & Welcome to the Forums ...
I'm sure someone will be able to assist you shortly with your post.
Ottoman
Haven't noticed any smoke but can get my other half to drive behind me and check that out tonight.
