I have a Clio 1.2 16v Dynamique and yesterday whilst travelling on an A road @ 70mph, the revs shot up an additional 2k to maitain the same speed, then not long after that I lost power to the wheels completely. I managed to limp it to a layby, lucky there was one just ahead, and called for a tow.
With the engine off I can select every gear without using the clutch pedal, with no grinding. It feels like I have the clutch pedal pressed when using the gearstick.
The clutch pedal is an inch or so higher than the break pedal, but i'm not sure if that was the case before this to be honest.
When this first happend, and still in the layby, there was a big smell of burning.
Would you say this will be a replacement clutch needed and that should be job done, or hopefully something even simplar?
