My car recently scraped by the last MOT emissions test and I have a cat 202 error so all the symptoms seem to be pointing to replacing the cat as it has been destroyed somehow....
I've had several garages quote me in the region of £300 to replace the cat alone, and it'll be a bit more for the lamdba sensors. I was hoping to save a bit of money and do the job myself though - I've seen a cat (approved) online for just over £100 and sensors for £40 each so I could save myself a lot of money. Except I don't know how easy it's going to be. Does anyone have any experience with this kind of job? I'm fairly competant and have most of the tools needed at my disposal - I replaced the discs and pads on my car recently and done a few other small bits and bobs like checking the rear shoes and replacing spark plugs etc etc.
I had a look under the car this morning and the cat is attached to the intermediate pipe via a clamp and the other end is attached to the end of the engine manifold via 3 bolts and a gasket.
The problem: The clamp bolt and the other bolts are pretty corroded and I couldn't remove them with my spanner and the manifold nuts are difficult to get to from underneath the car.... Is there anything I can do to make removal of the cat easier? I think adding the new cat will be fairly easy, it's just removing the old one that will be difficult.
