Hi All
I'm hoping someone can help me on this brilliant forum. After 30 years of amateur spannering I'm finally stumped and it's my daughter I'm letting down.
She has a 51 clio 1.5dci that developed a problem when starting a couple of weeks ago. once it did start it ran perfectly. eventually it wouldn't start at all.
I towed it home and snap dignosed glow plugs. - while changing these i managed to snap two off in the head - now my woes increase!
one week later - head removed - glow plugs drilled out and heli-coiled - head replaced with new timing belt, gasket, head bolts etc. Turned the key - exactly the same problem - tries to start but wont.
I've followed the helpful leads on this forum and have since changed the TDC sensor and plug/flylead supplied by renault, swapped the 3 little black relays around, swapped the glow plug unit with the one from my clio to prove it and am now at my wits end.
No Dad likes to let his daughter down!
meant to say that before attempting start up the imobiliser light and glow plug light both perform as they should.
Can anyone help please?
