i have just got a clio 15dci and the airbag light has come on how can i get it off and if i cannot is it a dear job
R
You probably have a loose connection some where. Quite often it’s one of the ones under the front seats. Not 100% if making the connection again will turn the light out with out having the error code it throws up cleared?
i have looked under the seat and found that the wires have been soleded could it be because of this if i took it to a auto electrician would it be a easy fix or a exspensive one thanks
R
If the connections have been soldered they ought to be okay? It really depend how long it takes the auto electrician to find the fault so I wouldn’t like to say how much it’s likely to cost.
R
Yes that would be great if you post back as it's always good to hear the solution to problems.
As you say it may be of benefit to some one else :)
