I'm basically very close to buying a particular Clio 182 however one thing has stood out (of what is an unabused 182):
From the seller
Nov 2010:
Replaced timing belt, aux belt, cam seals and resealed camcover and oil decantor (Nov 2010, £1100)
Aprol 2011:
Replaced water pump and aux belt kit replaced (April 2011, £600), Renault have carried out a health check last week.
Now I'm in two-camps, either the garage couldn't pin-point a loss of oil or squeek or slip etc so did the job twice? Or its just good maintainace?
Hi there & welcome.
What mileage was covered inbetween invoices?
I suspect that it was the water pump which needed replacing (on the second invoice), that wasn't performed at the first visit - probably due to cost reasons, which has come bacj & bitten the seller in the backside.
If there is a regular mileage between the 2 invoices (showing it hasn't been off the road in a workshop), it really wouldn't bother me.
HTH
Paul
Hi and thanks for taking the time to reply.
Serviced Oct 2010 (57309 miles)
Nov 2010 (£1100)- Replaced timing belt, aux belt, cam seals and resealed camcover and oil decantor.
April 2011 (£600)- Replaced water pump and aux belt kit replaced.
Current mileage 58,890 miles.
Something isn't right. Its only covered 1,000 miles Oct-to-April.
You are right. Yes the owner could have just used another car however with the work above it does seem like he was trying to rectify a failed pump or similar.
Thanks. Any tips on what to avoid etc (or link to common things to check muchly appreciated).
