hello
newbie with problems....
having spent many painful hours changing the clutch, engine subframe and numerous suspension components, now that we have this put back together can only get 3 and 4 gears, stick has reduced movement and change rod clanks against left hand support bar comming off subframe.
can someone guide us through correct procedure for setting this up.....we thought we had got it but then lowered the car and back to sq1...then i shut my thumb in the door..................good start to day!!:mad:
cheers
some progress made after another couple of hours under!
tried adjusting as haynes, but then put the clearance on the l/h side of the stick, adjusted the join between rod and box....now have got good R,1234 but very stiff to get into 5th
any ideas?:cool:
D
Just needs a little tweak to get 5th then. Put a mark on the linkages where you have it now, then loosen the clamp and give the gearstick a little nudge.
The way i usually do it is to put the box in neutral, loosen the clamp right off and get someone to hold the stick in the middle while i tighten the clamp
