Evening all, I'v had a search of the FAQ's, but i can't seem to find an answer.
I have a Clio 2, with the 1.9DTi engine (X REG).
Whilst all the electronics work in the car, i seem to be having problems with the lights, mainly the indicators.
Firstly, every time i press the brake pedal, the rear fog light indicator on the dash board lights up, then goes of when i take my foot off the brake pedal.
Secondly, The indicators work, however, when i indicate and then press the break pedal to slow down the indicators sometimes go off, almost as if they have frozen. Once i take the foot off the brake pedal they then start to flash again.
Finally, when i have my headlights on in the dark, the rear indicators do not work!. Instead, all the lights flash, including the break lights, almost like i have put on the hazard warning lights.
The problem seems to be with the rear lights as the front ones seem to be ok. I've removed the rear light cluster and had a fiddle and a dust down with a dry cloth, but this hasn't solved the problem.
Could anyone recommend a possible solution? I am clueless to the cause and the solution.
Finally and i apologise as its off topic for this section, but when is the cambelt to be replaced on the 1.9Dti engine?
Many thanks for your help and comments in advance.
