1 - 8 of 8 Posts
my clio2 sunroof is driving me mad.
its rattling (well more like creaking) all the time.
ive tightened all the 10mm nuts & its well lubed up, now im at a loss.:confused:
any suggestions please (other than turning my radio up lol)
Try smearing some silicon round the rubber seal or edge of the glass. Does you have pull-over blinds fitted.
no, its just a std elec tilt n slide with no blind.
the rubber seal did seem dry tho, & i did wipe autopglym vinal/rubber care around it with no affect.
same is happening to my sunroof? :confused:
well someone must know a way of resolving it lol.
spoke to a Ren tech & he said theres a fitting/refurb kit that may do the trick but its like 3 hurs + labour + the kit.
could be looking at over £300 as its no quickie job.
i was hoping there may be a quicker/cheaper option.:(
Creaking Sunroof
The creaking noise you describe sounds like something is moving - is it the frame against the body of the car or is it the window against the frame. Jamming a few folded paper wedges (temporarily) here and there might help find the source. When driving along does the noise stop when you put your hand on it. I don't like the sound of the tech guy when he says it might fix it.
1 - 8 of 8 Posts
