Hi all
I kindly ask for your comments on this matter. Please contribute if you have any insight, thanks.
My Clio 3 petrol, 2011, with the D4F engine (1.2L, 101HK, turbo) has "decided" to spill ~0.8L engine oil in the engine compartment over the last couple of days. Even the bonnet is looking shiny.
It has done ~182.000km (113.000 miles).
The entire area with the alternator is covered in oil, and there is quite the air flow from the oil filler cap when I remove it (even in idle). I have also had to clean up a small puddle of oil underneath the car where I parked - which is how I discovered the issue.
Checked items:
1. My turbo is nice and dry, and there is no oil in the air filter box.
2. There is no oil in the coolant expansion tank and no excessive pressure that I can tell.
3. There is some emulsified engine oil below the filler cap, but it does not appear to be further in (I removed the filler pipe to check) and only ordinary oil on the dip stick.
4. No smoke (white or black) from the exhaust.
Car seems to drive fine and has no issue with starting from cold or running rough etc. It has not used any oil before this and it has not over heated to my knowledge (owned it for 2 years).
So, any ideas - other than a blown head gasket?
My personal theory is that there is a leak between a cylinder and an oil channel causing the engine to eject the oil topside as hot oil vapor.
The engine does not appear to be equipped with an EGR valve + cooler (are these for the diesel only?)
Please also check:
YouTube link to show airflow from oil filler cap.
Checked items:
Please also check:
