Hi all
I took my 2001 clio 1.2 ,16v to my local renault dealer because it would not rev past 3000 revs, they "clip" tested it and told me it had a fault code throttle pedal switch "c" circuit they said they had found a after ignition relay fault. Does anyone no what this means, and can i fix it myself as they want £90 to do a wiring check but most of the wiring is new.Can anyone help please.
Banned
Accelerator pedal sensor on your clio has 6 terminals
marked 1-2-3-4-5-6 disconnect multiplug from acc
sensor check at key on for a 5v feedat terminals 3 & 6. terminals 4 & 5 are both earths Terminals 1 & 2 are signal return wires At terminal 1 key on acc pedal fully depressed 2v's At terminal 2 pedal fully
depressed 4v's Hth Regards Mickeybo
