I have filled up my water bottle, so I can wash the windscreen!! but no water is comming through. Any ideas??
Can you hear the washer pump working when you operate the switch?
If you can,then either the system is blocked or the pump impeller has come off the motor.I've had this a couple of times before with Clios in the past.
If you can't hear the pump,then you need to check to see if you have voltage getting to the pump when the switch is operated.If you have voltage,then the pump motor is past it,if you don't have voltage then you need to check the connections to the pump,the fuse and the switch.
