Okay my learned friends, fixed coolant in starter motor (inlet gasket gone) but now My Daughters 1992 Clio 1.4 auto 'drops' down a gear & stays in that gear until restarted; the Electronic Fault warning light comes on at the same time.
It's the AD4 gearbox, which works ok sub 35mph but seems to dislike anything faster.
Gone through wiring & pulled apart connectors to the various sender\sensors .... nothing pyshical spotted, like bad contacts etc.
Removed the transmission cooler box, inlet & outlet choked with brown sludge
flushed with a power washer & is clear. Put hose pipe into cooling system & flushed gunk from that to!!
Topped up ATF fluid (as per a posting) put back pipes, coolant etc. & off for test drive ...... smoother, felt good :d & then BOING! same thing, dropped a gear & locked in it
Stopped, switched off, then re-started & all was okay again, no fault light & changed through gears fine, stayed fine until I went over 30mph.
Read lots of related posts, some faults very similar to this one, most pointing to another gearbox.
It's a nice car, daughter's very fond of it, but a new box is too much for my pocket & more than the car's worth.
(did the AD4 stay in production for a while, is it worth trying to find a lower mileage, 'newer' box?)
So, unless any experts can point to a different conclusion, this Clio baccara is heading for the tip & the daughter is heading for the buses.
