Flushed with success at replacing the crankshaft sensor on my daughters '02 Clio, I thought I'd solved the starting problems. Although the car will now start each time, it hesitates and stalls when cold but drives fine once warmed through. I suspect the Coolant Temp Sensor but cannot find a "how-to" showing its replacement anywhere on the Net. Can someone briefly explain where exactly the sensor is located and will I need to drain the coolant to fit a new one? I'll try and take a few photos of the job and post them for future reference as it seems this is a common problem.
Thanks in advance. Russ
