Hi all,
my 03 plate 1.5 DCi Clio has problems starting when cold. As you will be aware it has been hot recently and has little problem starting during these hot days. I work night shift and in the cool damp morning air, the car turn over fine and kind of starts at very low revs and then cuts out. During this time the accelerator pedal has no effect. After a few attempts, it will again appear to start at very low revs and then will suddenly increase revs to the correct idle speed and all is then well and responds as it should.
I have changed both the glow plugs and the fuel filter (both were kinda needing it anyway) but this has had no effect.
Any suggestions as to where to look next.
Thanks in advance
Ali G :crazy:
Discussion Starter #2
Hi All,
Do I need to add any more detail to this, or is it a real brain teaser. Not being flippant. Happy to add further deatils if asked what info required
Ali
