Hi all.
I'm hoping one of you will be able to help me with this ongoing problem with my wifes clio dci.
We are having problems starting it, from cold OR warm. It is an intermittent problem and I would say it happens 1 in 3 times we try to start it....sometimes more. When its playing up, it may start, but will either stall straight away, or idle lumpy. It will also, sometimes, idle fine, but when you try to rev it, it feels like its running on 2 cylinders. More often than not, when you turn it off, and then back on again, it will be fine, but there have been 3 instances now where it will not start at all and the car has had to be recovered!
I gave the battery a good charge the other day, and it seemed better, but may be a coincidence. I have also just changed the fuel pressure reg and sensor, the camshaft sensor, and the glowplug relay. I did notice, AT TIMES, that there was a permanent 12v to the glowplugs, even after the light had gone out. I have also had a leak back test done on the injectors, and it showed them all to be fine.
We had the codes read the first time it happened and they are as follows:
p0830, p0089, df009(actuator relay circuit) , df064 (vehicle speed sensor error).
I must add, that once started and running right, its fine for the rest of the journey!
Any ideas?
Any ideas?
