1 - 9 of 9 Posts
Hi there, I have a Renault Clio. 02 Plate. 1.2 Expression. I need a fog light kit for the car. where is the best place to shop for it. I need the whole kit including the wires etc. any recommendations ?? thanks
The UCH will need to be re-programmed if you want to use the Renault switches,but it would be possible to add your own switch and wiring independantly.:)
Hi Badboibil - you wanna know the cost - it depends on which option you go for - is it going to be the Renault fit or independent. For the Renault contact your friendly dealer - he will gladly give you a price. For the other option try a local auto electrician. But at a guess Renault could charge £200. Remember you'll need to get the new spots aligned.:crazy:
ok thanks. ive bidded on the item. hopefully i can win the auction then get quotes for the fitting. what else will i need in addition to the fog lights in terms of wiring etc.
1 - 9 of 9 Posts
