Hi and good evening to all, am new to your informative forum having recently got a 2001 Clio sport 1.2 for my son when he passed his test.
Have looked through threads and done a search as requested on homepage, but cannot locate a solution so hope someone can help please:
Nearside front foglight is not working. Have swapped bulbs with offside (which does work) and bulb is ok.
No mechanic but where do i go from here before buying new foglight unit ??
Regards, Paul
Universal
I'm not sure if they are the same as the Megane, but the power for the fog's is on the passenger side, and then wires run from that fog to the drivers side one. So if it's the same, then there's something going on with the actuall wiring.
I would just check to see that no wires are broke, and also have a look at the connector on the fog and make sure it's clean.
Oh yes, I ment to say check the connectors on both of the fogs :d
La sola lupo
Im with FoxOkay in this, check the connector and wireing, maybe also the fuses but I'd think both fog's would work on the same fuse. (you never know)
