Hi, My front fog lights aren't working, i've tried the fuse box and replacing the bulbs but still not working anybody any ideas?
Do you have a test light? If so.. take the connectors off the back of the fog lamps and test it there, see if your getting power til that point, if so theres something at fault with the fog lamps bad connection/broken connection. If not the circut is broken between the fuse box and the connector
Barry.
Also make sure that you car getting the click noise from the relay when the front fogs are switched on as that is often overlooked.
This may sound a tad horrible...
but makes sure your normal headlights are on when testing/using your foglights!!
My friend (yes... my friend :rofl:) was testing the lights on the car and the foglights didnt work... so then he (or she) turned on the normal lights and funnily enough on came the foglights!!
Thats normal, headlights need to be on for fogs. Some cars even have the fogs on the stalk and set up so that if you try to turn them on it turns your headlights on too.
Any news? You got them working?
Barry.
