This is my first post on the forums so be gentle please, and I hope Im posting in the right forum.
I have a 2000 Clio, where the Drivers side handle (the inside plastic lever and casing) has broken so the door does not open from the inside.
I assume that this part will be easy to fit myself so I was looking on ebay for the correct part. Is it the cable type of door handle that I need ? Also would a rear O/S handle do the same job as the drivers door handle?
Any help appriciated. Thanks
Alan
Hello & Welcome to the Forums Alan.
I'm sure someone will be along shortly to assist with your post.
Ottoman
Discussion Starter · #4 · (Edited)
Many thanks for your welcome and help..
Bex, that is great. I will drop you an email tommorow morning when I get near a PC where I can access my mail.
Thanks again,
Alan
Last time i tried the dealers i believe they were asking for £50 a pair (25 each).
You can probably pick up a handle from one of your local scrappers for a a fraction of the price.
The cable in your handle should detatch and you can just slot it into the new handle.
