Clio 1.2 2004. 110000 miles.
After engine has been running for 5 minutes if return to neutral such as at junction then engine idles at about 2500 rpm.
Details: engine speed stays nearly at previous in gear speed and moves hesitatingly to this speed. Idling is ok on engine start and occassionally returns to 1200 rpm or even correct 800 rpm. Seems a bit hesitating accelerating and changing gear though could be just because trying to avoid this problem. If let idle a long time then speed can correct itself or even go up slightly to say 2800 rpm. Perhaps need to keep revs up when leaving neutral as can then stall and then be difficult to restart for say 2 mins.
