Got a problem where the car will blow fuses everytime I turn the AC on. Want to test the AC control relay as i've got one clicking but i've got no idea which one it is?
Anyone know whats what in the engine fuse/relay box? Theres no key on the inside of the lid and nothing in the manual, haynes manual or dialogys I can find.
Hi when the relay is ticking because you are switching it on and off if you put your fingers on top on the relay one at a time you will feel which one it is or when it is ticking pull one out at a time until you find which one it is i hope this helps as i have no idea which is which good luck Donald.
I know which relay is ticking but i've got no idea what the relay actually does or which one is the air-con control one?
