Hey,
right my mums clio is being a pain again,
ive read loads of interweb pages regarding the problem, but none ahve given me a way to check if its the fault i think it is.
The problem:
When starting after long periods of no use (24hrs+) the car will turn over and only start if you floor the accelerator pedal, then start and then imediatly die. You have to keep reving it once started for 30secs and then it goes to idle, a little lumpy but ok.
What i think it is:
Either the Crank Position Sensor OR Fuel Pressure regulator.
Done so far:
-Changed Sparks
-Cleaned CPS
-cleaned and checked inlet and filter
-new battery
so basicly how can i test these sensors? am i right? what are your opionions?
any help much apreciated.
Tony
The problem:
What i think it is:
Done so far:
-Changed Sparks
-Cleaned CPS
-new battery
Tony
