Hello,
Any advice out there regarding a fault on a 2006 Clio III 1.4 16V auto gearbox? Has occasional tendency to slip into safe/limp mode and "check gearbox" warning light come on. Only happens early in the day, not (so far) when engine is hot. Stopping and restarting engine clears problem - until the next time. Gearbox oil topped up last week (had got a bit low). Renault garage suggests new automatic valve chest required, but this seems a bit drastic (and v. expensive).
Is it only likely to happen when engine is cold, and is there an easier (less expensive) fix? Car has only done 39K.
Thanks very much for any advice!
