Hi all,
After replacing my rocker gasket in an effort to fix a small oil leak it appears there is still a leak!
The oil looks to be coming from the bottom of the inlet manifold - Does oil leak from here? If so is the gasket as easy to replace as the rocker cover? The Haynes manual looks fairly simple!
Engine is a single point injection (E-Type)
Thanks!
Thanks!
