I notice in the vid showing lamp changes on a Clio IV, at 02:42 when they change the indicator bulb it shows them changing the whole assembly. I hadn't seen that type of bulb before so of course I tried to look up the bulb and couldn't find anything that looked like that listed on most spares sites if you chose Clio IV as the vehicle. I eventually discovered it's a PY24W and the bulbs are £14 -£18 or more!
(I think a that price I'd be tempted to graft a standard amber 21W in hoping the canbus wouldn't complain although not sure if it would fit)
Automotive tire Automotive lighting Hood Automotive exterior Bumper
Automotive tire Automotive lighting Motor vehicle Automotive design Automotive exterior
Super mod..
I hope you enjoyed the vid.. I'm hoping to find more as time goes on and to build up the info base so members can see without asking a question.. should give me more tea and chocolate biscuit time.. 😋
The bulb is a PY something bulb. There cheap enough to fix and I think their designed like this, due to creating a high output beam pattern.
