Hi All,
Right then here goes:-
I have looked through a lot of threads and this seems to be a very common problem!
My Clio 2001 decided not to start the other and was turning over but not firing up, thought it might be the battery in the key so changed it and no difference.
When i turned the engine over the key would seem to be disabled and then not control the central locking until I re-synced it.
Cut a long story sort I took it into Renault and had the diagnostics test - the outcome was a new key and a new ECH? (Not heard of ECH but thats what it says on the printout - is this a typo for ECU???)
Before I go and spend my hard earned £600 on a bloomin key and box of tricks is there any cheaper way of doing it?
Please help as I need to get my car running again and am tempted to just sod it and get the work done :-S
Thanks.
Thanks.
