Hi can anyone help me please. I have a Renault Clio Expression 2001 and like everyone else it has a leaking sunroof. Can anyone suggest somewhere in the West Midlands I can take it to get it fixed, it needs a new rubber seal because it is all cracked and has a lump of rubber missing. I know there are hundreds of posts on here about this problem and I've posted on here before but only got suggestions on fixing it myself. I don't want to do it myself I'd like to take it to someone who knows what they are doing.
Hi. Any local garage should be able to replace this seal.
I'm replying to give you some more info. I've had a sunroof leak on my 2001 Clio and went to a Renault dealer to buy a seal (the seal which is visible under the sunroof glass) and was quoted £100+ to supply the part.It does sound like your seal is not in good condition.Perhaps a scrapyard would be a better (cheaper) option to find a seal.
Luckily,I did not buy this seal and after some investigation, found that the source of my leak was the seal under the sunroof frame. If I had replaced the seal which is visible under the glass I would still have had a leak!
Hope this might help.
