1 - 10 of 10 Posts
Hi can anybody advise me if i can change a full ecu kit over from a similar car without having to reprogram anything?
Sexy at 70 super duper mod..
Ok I now understand..but let me say this..when you transfer items like ecu's uch over there is no guarantee that they won't also be faulty..in the case of an ECU they can be carrying faults to your car from the donor vehicle..if it was me I would send off the UCH for examination and rectifying and you will retain the same coding to your clio and usually with at least a 2 year warranty so won't need the other parts..
Still worth inquiring about before you make the leap..plenty of companies on the net that can even repair that..its up to you at the end of the day and can only offer you that bit of advice..good luck with whatever you decide..馃檪
1 - 10 of 10 Posts
