My boot door is not opening at all and everytime I press unlock/lock the car there is this buzzing noise coming from the rear end of the car. What problem have I ran into?
you will have to crawl into the boot and get at the lock from the inside, normally there is a piece of white plastic that you can fit a small screwsriver into and slide it sideways to open the boot, when you have it open you can start to try and diagnose the problem
Just had a look on youtube and looks like its the actuator motor that needs replacing , common problem on the clios
