My passenger side rear light has gone and not sure which bulb I need to replace. Its the light when you switch on your normal headlights the back automatically stay on. Is that called a sidelight or tailight?
Tail Light ( side Light is the small torch bulb in the headlight )
  • Like
Reactions: jjb0800
Thanks for that, my front foglight dtiver side has come out of place, how do i stick it back in?
the front fogs don't just 'come out of place' have you hit something ?
they mount from behind but I can't tell you how as both daughters & her partners Clio's don't have front fogs.
You will have to remove the front inner wheel splash guard & take a look, they may just clip in but I suspect they are bolted in
& some plastic part has either got broken or someone else has been there & left a screw / bolt out ?
Tail light bulbs are easy, the drivers hand book will tell you how to remove the lights unit and fit a new bulb.
(they push and twist just like a house bulb.)
Tip - test its working before you re fit the light unit.
Al
Oh ok my car has been in the garage it would be them who have done something to it
Fog lights are held in from behind with two torx screws. They are accessible with the inner wheel arch removed.
