Hi every one
I am trying to find the positive and earth feeds from my reversing lights to power a camera in the car when the reverse gear is selected, could you please tell me what colours the positive and earth cables are? Thank you an image is attached below showing all the cables going in the the lights.
You're best option is probably to check the wiring with a circuit tester to find the correct cables.
Check each cable with all lights off then - with the ignition on - put the car in reverse and check the cables again. The live one will be the reverse.
Or a closer look at the printed circuit board should lead back to the correct pins on the multiplug and then the correct wires.
I suspect one may be a common earth for the light cluster.
  • Like
Reactions: Zacsimmo
Thanks for the advice Gonescenile I have managed to wire the camera for any one who is trying this the (black wire is earth) (and the White is live when reverse is selected.)
